2007-09-05 09:12 PM - last edited on 2023-05-24 12:44 PM by Rubia Torres
2007-09-05 10:09 PM
2007-09-05 10:15 PM
2007-09-05 10:15 PM
There are window opening objects. These are just blank openings you can insert into a wall.Is that really the best available (or only available) option for going about this? In the event that I change or move a window I would then need to change and move a second object every time. That seems rather tedious and I thought there would be a far better method.
So you would just insert a blank window opening into the wall directly opposite the window in the other wall
2007-09-05 10:17 PM
2007-09-06 12:15 AM
Jacek wrote:
Why are you creating a composite wall out of individual walls instead of a single composite?
What are you trying to do?
2007-09-06 01:39 AM
2007-09-06 02:02 AM
Jacek wrote:Wow, I'm not sure why I let that method slip by me. Thank you. It's so obvious I can't believe I missed it! (I'm not being sarcastic, by the way.)
OK I would use composite walls and use the floor slab to "Subtract" the wall elements with "Downward Extraction" to achieve something like the attached section. You can further play with it to achieve the desired profile.
2007-09-06 02:27 AM
2010-01-23 02:25 AM
