Window cannot be smaller than 1,160 m
Hi folks,
i have question about the window width. If i set 500 mm as you can see on image, i can't set the window smaller than 1,160 m. Does someone know any solution?
Cheers.
1 Reply 1
Erwin Edel
Try a different window, the window shown is not that complex to use the 'multi' window. An easy one to use would be the 'repeating vertical' window.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
