Tom Krowka
Window display
OK, I give up. How do I get a window, placed 8 feet above the cut plane, to display on the floor plan. There are no projections in this window that stick out past the wall, so now what? Have tried all four options on the floor plan display. At least if I could get the marker to show up, that would help.
Thanks.
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
3 Replies 3
Thomas Holm
Try to set the wall's display to Symbolic Cut (the wall will only show in one storey) AND the window to Symbolic.
If you have a multi-storey wall, it has to be set to Projected with Overhead AND the window to Symbolic, otherwise the window won't show.
Tom Krowka
Thanks. Did not realize that both elements -wall and window- had to be set.
[email protected]
www.walshkrowka.com
Thomas Holm
No problem!
