VGDD
Window frame incomplete in 2D
Can anyone please explain why the back face of the window frame that abuts the wall disappears but it doesn't on doors?
Archicad 11 - 27
Windows 11 Home
11th Gen Intel(R) Core(TM) i7-11700K @ 3.60GHz 3.60 GHz
32.0 GB
2 Replies 2
Guru
I believe it is the gs_frame_[side]_endline boolean parameters which are hidden as far as I know, and are set to 0 unless you have a frame tolerance set for that side...
VGDD
Thank you for your reply Lingwisyer. Frame tolerance is my work around.
Archicad 11 - 27
Windows 11 Home
32.0 GB
