Streamline your workflows and master BIM coordination! Program starts April 28.!
Window marker offset
Steve Jepson
Is there a setting in the GDL script to correct this problem ?
Shot at 2009-08-14
Hi Steve,
It seems that the problem is within the window marker...
Which one are you using?
David Maudlin
Steve:
It is a function of the leading of the text that is part of the font (see example below, note the location of the text handles). You can try changing the font to get better results. It looks like you are using the Builder Dimension 12, which does not have an editable hotspot or parameter for moving the text.
undefined
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Steve Jepson
Thanks. It does fix my problem if I change the font.
