Window on composite walls: section insulation
I have this problem.
I have a composite walls, with structure and internal insulation. I set the parameters correctly (insulation is a finishing, as well as plaster). When I create a window in the wall:
- on the floorplan view I get the correct insulation.
- in the section view instead, the insulation as well as the plaster won't turn and hence the window is attached to the structural part of the wall.
How can i get the same result in the section and floorplan view? I attached an image of the section, hoping it clarifies better what I am experiencing as a problem. Thank you for any feedback
16 Replies 16
Happy to hear it worked. Although now it seems we are both stuck in the same situation where only the floorplan works ...
Dontknow
Still no luck here getting it fixed in the section view.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
I've been trying for days, that's why I decided to ask the forum. I'm sorry I cannot help you further...
Let's see if someone here might give us the final information in order to be able to do it.
Dontknow
Well, I'm the one who is sorry that I can't help you further.
ArchiCAD 25.
Dontknow
The only thing I can think of right now is to draw it in.
ArchiCAD 25.
Thank you for your help and interesting conversation. I sure hope we do find a way...
As far as I know the 3D Script of Doors and Windows is not written in a way so that those skins turn in 3D. This is why you don't see them in Section.
