Window's above doors show up in plan?
I have storefront windows placed at 9'-0" above an 8'-0" door. In plan I see the window above the door. I don't want to see the widow above the door. I have changed the window setting to "projected" but the window still shows up. I have set the cut plane for the plan to 4'-0" and still no luck making the window above the door not show up in plan. Any suggestions?
Thx,
6 REPLIES 6
TomWaltz
The easy way is to turn off the window's 2D display, under the "2D Detail" parameter.
Tom Waltz
Thank you for the post. I have tried that too.
I still have the problem though....
There is a door in the storefront system from 0'-0" to 8'-0" and the window above the door (9'-0" to 12'-0") still shows a outline cutting across the door. I do not want to see the window above the door at all.
Do I have to place another wall on a no print layer (3D only) and place the window above to pull it off? Or is there a simpler fix?
Please help.
Thx,
TomWaltz
Just turn off the "Wall Contour Line" parameter.
Tom Waltz
Tom,
That did the trick! I was thinking too indepth.
where is the wall contour line parameter on - off switch?
Click on the window you want to edit.
Hit (CTRL+T)
Look in the "PARAMETERS" tab
Go to "Floor Plan Symbol" tab
And there are all the settings you should need.
