Window with different thickness of inner frame
Hi maybe is't super simple but couldn't find out right window for my case.
I wanna have quite simple window witch 3x2
But I with inner frames with thicker 116mm because behind the window are pillars
I can do that all of them have 116mm but this is not what i want.
I cane make model with two windows like this :
But after then I have two windows and for my windows schedule it's not good for understanding
Can i merge this windows somehow ?
I need just good kick 😉 where is the good window for my case.
I don't wanna do curtain walls for just this.
Thanks for any advice.
AC 7 - 27 SWE
MacBook Pro, M4 Pro
1 Solution
Joe Logiudice
Graphisoft Alumni
Graphisoft Alumni
Hi, try to use Triple window
divisionsdivisionsframe widthframe width
Giovanni Logiudice
Educational Community Expert, Moderator
Certified GRAPHISOFT ARCHICAD BIM Manager
Go to post
2 Replies 2
Joe Logiudice
Graphisoft Alumni
Graphisoft Alumni
Giovanni Logiudice
Nice thanks 👍
AC 7 - 27 SWE
MacBook Pro, M4 Pro
