Windows - Wall closure - Side Jambs and Head Jamb not identical.
Hello there!
I am trying to set up some windows and doors with specific parameters. For example I want to turn in and cover the jambs with insulation, but anything I do with options (reveal, wall closure, etc.) the setting does not apply fully to the head jamb. See the pictures.
Any clues?
1 Solution
Lingwisyer
Guru
Object limitation. Details like these are not modelled by the object in 3D and hence cannot be seen in the section. There might be a 3rd party object that does, but as far as I know, none of the GS objects do.
Ling.
Go to post
4 Replies 4
Lingwisyer
Guru
Ling.
Ou... that is... disappointing. Thank you anyway.
Do you think that this problem is... eligible to ad to the wish list? I would like to see this corrected.
By the way, what experiences do you have guys with the wishes/wish list? Does they get resolved? Do the developers read that forum posts?
Lingwisyer
Guru
Pretty sure there is a long time wish for this somewhere...
Quite a number of wishes appear to get forwarded to the dev team, but from what I have used and voted on, additions related to said wishes are far and few between from what I have noticed.
Ling.
Here's one from last year: https://archicad-talk.graphisoft.com/viewtopic.php?f=25&t=44615&p=303830&hilit=window+closure+sectio...
Sad.
Anyway, thank you for the answer.
