Windows in Custom Profiles
Bob Moore
I have a custom profile wall with a brick base and EIFS above. When I install doors and windows the plan view show tem aligned in the metal stud wall but the 3d view show them to be clearly outside the EIFS face. If I adjust the reveal so the 3d shows proper alignment in the wall the plan shows the window or door to be inside the interior space.
Attached is a view of the first circumstance.
AC 7 - 29
iMac 27"
Mac OS Sonoma 14.0
3.1 GHz 6-Core Intel Core
32 GB 2667 MHz DDR4
Radeon Pro 575X 4 GB
5 REPLIES 5
rocorona
Did you adjust the "opening reference" lines, in the Profile Manager?
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
JLopes
in your case I believe it is possible to control, not having seen any frame from the outside (see figure 1);
if you have think outside the frame is not possible (see figure 2) I could not do.
|| JLopes ||
AC29 Port || Ryzen 9 5900x | RTX3080 | Win
Generally this behavior (bug IMHO) happens because windows/doors ignore the opening reference line and instead "read" the thickness of the wall at the 'anchor' for the window/door.
In this case, change the window 'anchor' in the settings dialog to be the 'head' - which is the thinner EIFS part of the profile - and things should come out OK.
The Reference Line has never worked as advertised IMHO.
AC 29 USA and earlier   â€˘   hardware key   â€˘   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Bob Moore
Thanks,
I had the reference point at the face of the exterior sheathing. I went back to the profile manager and removed the footing and the window frame move slightly but it is still outside the face of the EIFS wall. See attached.
I changed the the anchor point in the window dialogue , and the opening reference in the profile but that didn't have any effect.
What I find odd is that in plan the frame is exactly where it should be.
Are there any other work arounds?
AC 7 - 29
iMac 27"
Mac OS Sonoma 14.0
32 GB 2667 MHz DDR4
Bob Moore
OK.
I went into the profile manager and moved the outline(which I now realize is the opening reference line) that was previously at the face of brick to the reference point. Works perfectly.
Thanks
AC 7 - 29
iMac 27"
Mac OS Sonoma 14.0
32 GB 2667 MHz DDR4
