‎2016-04-05 09:26 AM
‎2016-04-05 10:34 AM
‎2016-04-05 11:52 AM
Barry wrote:
You can REQUEST the Archicad license (key) number (Serial_number) and if this matches one in a list of numbers you have in your 'license' object then the object script can run - if not then END.
You will need to know the license numbers for you client of course.
And I believe this will not work if they are using the software keys as I think the numbers can change.
Only works with the Codemeter (or old WIBU) keys.
‎2017-11-03 06:50 AM
