X Y co-ordinates of the object
dhaval7shah
How can I get X-Y co-ordinates of an Object, through its own GDL script?
I also want to take the same data in to Schedules. Can anybody show me some example of such scripts.
(I tried with e.g. x1 = SYMB_POS_X , but i think i dont know how to use this Global parameter?)
Thanks.
Dhaval Shah
Upto AC 22
iMacs and MacBookPros: Mac OS X (10.6 to 10.12, Intel core 2 Quad to i5, i7, 8 GB to 16GB)
Win 10, AMD Opteron 6-Core x 2, 16GB, FirePro W4100 2GB
& ThinkPad E550
& i7, 8GB
9 REPLIES 9
alemanda
In you gdl object you should define two parameters and assign to them the value of SYMB_POS_X and SYMB_POS_Y. Then you should add these two parameters as filter in your schedule.
Hope it is useful.
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores) - 32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 2560x1440
If I remember right, the object's coordinates are always zero in the schedules
Regards, Juha
Does this post about the GLOB_WORLD_ORIGO_OFFSET help?
http://archicad-talk.graphisoft.com/viewtopic.php?t=33878
dhaval7shah
!!!!! Master script Part !!!!!
If bUpdate then
Xx1 = SYMB_POS_X - Ooffsetx !X co-ord
Yy1 = SYMB_POS_Y - Ooffsety !Y co-ord
Endif
Parameters Xx1 = Xx1
Parameters Yy1 = Yy1
Xx1Last = Xx1
Yy1Last = Yy1
if bUpdate then
Xx1 = Xx1
Yy1 = Yy1
else
Xx1 = Xx1Last
Yy1 = Yy1Last
Endif
2D script part :
text2 0.2, (-r1+0.1), "x: "+ PreX + str ("%.2", Xx1*100)
text2 0.2, (-r1-0.05), "y: "+ PreY + str ("%.2", Yy1*100)
Text output comes correct But the taken parameters Xx1 & Yy1 in the schedule, are showing the valuae incorrect (i.e. it considers the value of 'SYMB_POS_X' and 'SYMB_POS_Y' as zero)
can anyone help on this please?
Dhaval Shah
Upto AC 22
& ThinkPad E550
& i7, 8GB
True.
Curiously, they do show correctly in basic component lists.
GDL oddities. Don't know if this can help.
dhaval7shah
yes, in Lists the co-ordinates cam correct, but there is still a limitation, when i duplicate the objects, i need to refresh one of its parameter to get the Xx1 & yy1 refreshed into the list. Otherwise they show duplicate co-ordinates.
Also somehow i could manage to show this X_Y co-ord values into schedules, but then the text out put is having the problem.
Can we use the PUT function here? do you buddies know how to use it?
(by the way this exercise is to prepare a co-ord table for Setting out points)
Dhaval Shah
Upto AC 22
& ThinkPad E550
& i7, 8GB
As Juha said, I don't know a way to display x, y coords in schedules.
Basic component list is the only possibility I can see for the moment.
May be Karl or other folks could tell you more.
Just in case,
!!! ----- Master Script -----
	x = xOff + SYMB_POS_X + GLOB_WORLD_ORIGO_OFFSET_X
	y = yOff + SYMB_POS_Y + GLOB_WORLD_ORIGO_OFFSET_Y
	z = zOff + SYMB_POS_Z
!!! ----- Property Script -----
	component "X Location", x, 'm'
	component "Y Location", y, 'm'
	component "Z Location", z, 'm'
No need to declare x, y, z as parameters., x, y will return 0.
dhaval7shah
Thanks Olivier. Do i need to define these components in database too ? and then add them in the 'components' window ?
Dhaval Shah
Upto AC 22
& ThinkPad E550
& i7, 8GB
Not needed.
Document > Shedules and Lists > Component Lists > Basic. That's all.
Export under the format you need.
To separate different objects, you can sort them by ID, for eg.
	component GLOB_ID + " X Location", x, 'm'
	! etc...
