Zone Additional Information
I'm wondering to put Finished Floor Level (FFL) information into the AC Zone object, either it is parametrically or just a type in format,,
Does any one know how to put a simple script on Zone GSM?
Much appreciated for the help,,
It certainly possible to add as a manual input parameter. There may also be a built-in parameter for the zone stamp subtype which would allow it to be automatic.
If you plan to write your own, I recommend starting from scratch. The included ones are very complex so as to suit a wide variety of uses. Your requirements are likely quite specific and easily written.
