Zone Areas into GDL object
Hi there,
Can I bring in/ request Gross Areas/ from zones into objects? if so how about zones from other windows/ stories?
This is for a floor plan stamp & also a coverage calculation stamp. For the site stamp The Site Area will be a user input. & the building outline will be drawn using a zone, I would like this area to be included in the object thus a formula then written so that the coverage percentage will be automatically calculated.
For the Floor plan stamp I would like to have a zone representing the floor area, then put into the object with another formula also providing the imperial sq. ft measurement. Also there will be a total floor plan area grabbing a zone area from another story/s & totalling them on the stamp.
I am pretty close on getting this working. its just the area request.
Help!
What I would probably do is write out the data I need from the script of the Zone Stamps into a File.
Then I would read that data from the file by the other object displaying those results.
You could use the GDL TEXT I/O or DATA I/O commands, or possibly even its XML commands although I have not tried that one yet so I have no experience with it.
laszlonagy,
Thank You for your reply.
Is there any examples in The ArchiCAD libraries I can refer to that work in the way you have described?
Dwayne wrote:
laszlonagy,
I honestly do not know, I do not know the library parts that well.
You can refer to the GDL Reference Manual to see how these file operations work.
