davide
Zone Stamp
Is the default "Zone Name" list for the Zone Stamp editable? I'm not referring to the final "Personal" entry. Thanks.
iMac i7 late 2009
10.13.6
Archicad 24
4 Replies 4
Aaron Bourgoin
yes. it's a Macro, I think. You may have to convert the lcf , make changes, and then re-convert the library to an lcf
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.0 USA
Rhino 8.33 Mac
MacOS Tahoe 26.5.2
Lingwisyer
Guru
Refer to this recent post asking the same question:
https://community.graphisoft.com/t5/Project-data-BIM/Making-naming-zones-more-convenient/m-p/693086#...
Regarding the library container, I would advise not packing and repacking it as that will undo your changes when ever there is an update. I would extract the stamp object and it's macro to your local library, then rename the macro and relink it in the stamp.
Ling.
Yves
There's no need to make a copy of the macro!
You can make the modification directly in a copy of the Stamp object that you save in your personal library.
Just add these few lines before the macro call, like this.
And you simply need to add the stRoomNames[zn] lines as many times as necessary.
dim stRoomNames[]
zn = 1
	stRoomNames[zn] = "Storeroom" : zn = zn+1
	stRoomNames[zn] = "Residence" : zn = zn+1
	stRoomNames[zn] = "Lift": zn = zn+1
	stRoomNames[zn] = "Bathroom" : zn = zn+1
	stRoomNames[zn] = "Meeting" : zn = zn+1
	stRoomNames[zn] = "Restaurant" : zn = zn+1
	stRoomNames[zn] = "Office" : zn = zn+1
values "ROOM_NAME" stRoomNames, custom
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
Patrick M
is there a reason you don't just have a handful of zone stamp attributes, then create favorites for each zone and info set?
seems like a more complex solution than you need for localized data management.
