angled stair GDL - function Demo
Hmooslechner
I recently programmed an angled stair for the normal stair-Tool - not the Object-Tool - with some abilities - the Stairmaker does not have.
The Stairmaker-Stairs are static after being inserted into the drawing. That should be changed! A 10 yoar old wish to Graphisoft!
My stair shall be seen as a possible "function-Demo" or Workflow-Demo" for later Graphisoft-Stairs - a suggestion for them!
It is inserted normally - but then - You don't need to open any further Dialogue box to edit the measurements and the geometry. Even the Hight of the Stair can be adjusted in the Ground Floor directly.
There soon will be a link to an english Youtube tutorial for it - its in upload now.
To try at home - on Bimcomponents it will appear as functiondemo-library-part in a few days - when they set it free.
You can find it under this name "ViertelgewendelteStiege"
A dropbox - link for the faster ones will follow sooner.
In the Meantime some german Youtubes:
https://www.youtube.com/watch?v=Tq4ln5m5kCs
and the further developments in german:
youtu.be/qaks3wUasaY
It will take some hours for the english Version until now!
9 REPLIES 9
Hmooslechner
Here is the english version of the Youtubevideo:
https://www.youtube.com/watch?v=A1Bn4wsmlrk
The video for english says its private
Hmooslechner
Sorry - its open now.
sinceV6
Well that is simply amazing. Great work! I have always loved the methods, theory and drafting geometry behind a balanced stair. I can only imagine the work behind the script.
Best regards.
Hmooslechner
Double - deleted..
Hmooslechner
https://www.youtube.com/watch?v=sIUU2H03dwg
Some progress with this part.
Its possible now to draw an every single inner side of every step.
There is a connection - freeforme-tube implemented to connect the stair with the slab below.
Hatches in 2D to make the stair more visilble.
some Textblocks..
Every Hight of every Step can be displayd.
Still buggy - but the concept works very smooth!
The part is still in german, but if You want to try it at home anyway:
https://www.dropbox.com/s/mqsf55aod3vei9a/ViertelgewendelteStiegeB.pln?dl=0
Hmooslechner
What's wrong on Bimcomponents?
I uploadet this thing recently again - i do this with every step of the development-progress - and got the return-message:
Your object has been uploaded successfully!
Dear Heimo Mooslechner,
Congratulations! Your object, ViertelgewendelteStiege, has been uploaded successfully to the BIMcomponents.com portal!
Your object is available at the link below:
https://bimcomponents.com/GSM/Details/20077
Thank you for sharing with the BIM Components community!
The BIM Components Team
Everything seems ok but then -
But if You follow the link You get an error message !?!
On the error page it says you can email to bimcomponents [at] graphisoft [dot] com.
You should try to contact them on that email with this problem.
Hmooslechner
Menawhile they set it free under new Nr.
https://bimcomponents.com/GSM/Details/20088
Its functioning now so far..
The GDL-development still will take some time that it will function as expectet by me.
To get a look at the progress in german:
https://www.youtube.com/watch?v=h6DftKmRb3E&feature=youtu.be
