Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
archicad 20 window 2d display problems
Hello everyone,
We take a window from the library with 2 sashs. We design to get one sash at 1/3 and the other one 2/3. On plan it will show half.
anyone have a solution
3 REPLIES 3
Could you state the name of the Library Part, and maybe attach an image showing both the 2D and the 3D of the library part?
I put the image of the window. This one exemple other window doesn't follow the 3d
It looks to me that you have the sash width set to 50% which is what the plan preview is showing.
You should find the elevation and 3D previews will be the same.
The diagram in the dialogue is just an example and not a true to size image.
