automatic A and B values
Hey guys,
I draw a lot in the 2d symbol putting things in different layers and using code like
IF layer1=1 THEN
FRAGMENT2 1,0
ENDIF
for every layer so I can turn things on and off.
The problem is the values of A and B don’t adjust automatically. I activated the “FIT size to 2D symbol” and the “create a bounding box”(compatibility options).
in layer 1 there is a box of 100 X 200
in layer 2 there is a box of 300 X 800
Archicad makes a perfect bounding box depending on the layer but the values of A and B are entire layers limits so they end up being always A=300 B=800.
Any code that i can make the A and B values= bounding box?
Thanks in advance
Luis
2 Replies 2
As well as changing the fragment for each different layer, you will also need ti rest the A & B values.
Maybe something like …
in the 2D script...
IF layer1=1 THEN
FRAGMENT2 1,0
ENDIF
IF layer1=21 THEN
FRAGMENT2 2,0
ENDIF
In the parameter script …
IF layer1=1 THEN
A= 0.100
B=0.-200
PARAMETERS A=A, B=B
ENDIF
IF layer1=21 THEN
A= 0.300
B=0.-800
PARAMETERS A=A, B=B
ENDIF
Hi Barry,
Thanks a lot for replying.
Ok, I though there was a way the program would do it automatically. ok then i will do it as you say.
Thanks
Luis
