automatic boxes
i'm trying to make a script of boxes that automatically puts one near one and if they're more than the master side they go on the next line.
actually i got the error of making more lines then the needed ones.
this is the actual script
for i = 1 to o_nmr step 1
block o_la , o_lu , h
if i * o_la < ed_la then
addx o_la
else
! for e = 1 to int( ( o_la * i ) / ed_la ) step 1
! if o_lu * e < ed_lu then
! addx o_la * int ( ( ed_la - (o_la *i) ) / i )
! addy o_lu
! endif
! next e
endif
next i
got tips?
7 REPLIES 7
I'm not sure I understand your description, but I think what you are looking for is:
if i * o_la > ed_la then
Keep in mind that this will repeat for each remaining value of i after the condition is met.
now i'm doing with a different script and more clear to read.
this is the new script...and similar problem...
for e = 1 to int ( obj_nbr*obj_lenght/length_max) step 1
for i = 1 to obj_nbr step 1
block obj_lenght , obj_width , heigth
if int (i * obj_lenght / length_max ) < 1 then
addx obj_lenght
else
del top
addy obj_width*e
addx obj_lenght
endif
next i
next e
del top
mulz -1
block length_max,width_max,0.1
Two things that may be problems...
This will only execute more than once if the combined length of the objects is twice or more times the maximum length. This may be what you intend but I don't quite understand the logic. Is your intention to only model complete rows and leave off the last partial one?
The only integers less than one are zero and negative. This is a curious way to do this. It also means that on the second row it will only execute for (approximately) half of the blocks that fit in the max length, on the third row for only a third and so on. I doubt this is your intention.
Overall I find your code a bit difficult to decipher. If I understand what you are trying to do, this is how I would go about it...
block_lg = 1.0
block_wd = 0.5
block_ht = 0.25
max_lg = 10
total_blocks = 36
number_X = INT(max_lg/block_lg)
number_Y = INT(total_blocks/number_X)
FOR i = 1 TO number_Y
	FOR j = 1 TO number_X
		Block block_lg, block_wd, block_ht
		addx block_lg
	NEXT j
	del j-1
	addy block_wd
NEXT i
This code skips the last partial row (as yours appears intended to do). To model the partial row you can change line 12 above to read:
FOR i = 1 TO number_Y + 1
or...
FOR i = 0 TO number_Y
Note the statement "del j-1". It seems that GDL increments the loop once more than you might expect (apparently one last time when the condition is NOT met) this makes the number of transformations one less than the final value of the increment variable ("j" in this case).
One other thing, I generally try to avoid using the "del top" statement. It's fine for simple parts, but as scripts get long it should only be used between clearly distinct sections of code that you want to absolutely share no transformations. Otherwise it is good to get in the habit of counting out and deleting just the number of transformations necessary.
really impressive how much it is clean the code!
now i'll try to read more about this script you suggest beacuse it doesn't make to stop blocks if they're less than a row or too much for an area.
i'm thinking to see if it is possible to make a second or more level with this kind of script.
it is hard to get a script for a right tiling of boxes.
with the for..next loop it is only going to multiply the row if the boxes are more then the maximum of it.
i would like to make it stop with the exact number i put in the parameters.
is there any script that can tell to stop?
now i made a transitional script as the one posted
obj_width = 3
obj_lenght = 2
obj_height = 0.5
obj_total_number = 8
area_width = 10
area_length = 15
area_thickness = 0.1
x_objcts_on_area = int (area_width/obj_width)
y_objects_rows_on_area = int (obj_total_number/x_objcts_on_area)
for k = 0 to y_objects_rows_on_area step 1
for j = 1 to x_objcts_on_area step 1
block obj_width,obj_lenght,obj_height
addx obj_width
next j
del j-1
addy obj_lenght
next k
del top
mulz -1
block area_width,area_length,area_thickness
i still got to think how to stop the script when it has got to 8 instead to make 9 boxes!
is there any stop command as other languages? could end script help?
solved
obj_width = 3
obj_lenght = 2
obj_height = 0.5
obj_total_number = 2
area_width = 10
area_length = 15
FOR k=1 TO obj_total_number
    BLOCK obj_width, obj_lenght, obj_height
    ADDx obj_width
    IF k MOD x_objcts_on_area <.001 THEN
        DEL x_objcts_on_area
        ADDy obj_width
    ENDIF
NEXT k
del top
mulz -1
