Hi all
was just wondering if there is a reason that when you assign a building material in GDL scripting to an object but it doesnāt show up in schedules when using the assigned building material as the criteria ? i can elaborate if need be.
Well, you need to check for a library parameter. They are not directly linked to the other tools' parameters, so you need to have an additional criteria in your schedule. (It hides under the little arrow...)
