Formworks,
Glad to hear you're finding some of my toys useful!
One thing to keep in mind for folks new to this software - Try to think a little wider than what an object is called in it's file name.  In reality, a refrigerator is just a glorified cabinet... You could really use any suitable cabinet object to make a refrigerator, or any other type of 'cabinet style' appliance.  A good example is dishwashers... I don't use a 'dishwasher' object... Rather, I'll use a single door cabinet, turn off the drawer, then adjust the handle parameters to get the handle positioned and looking the way I want.  For scheduling, I've created parameter objects which are invisible on the working drawing, but get 'read' by the scheduling function.  My dummy objects are coded with all the standard data fields to suit my schedule schemes.  Additionally, I've setup parameter objects for most of the things I schedule frequently such as appliances, mechanical parts, plumbing fixtures, electrical fixtures, etc.  If I don't have the precise object I need for the working drawing, I'll place a substitute object in the model that =looks= the way I want and give it an ID that will be ignored by the schedule scheme, then place the appropriate parameter object on top of it.  I give the parameter object an ID that will be recognized by the schedule scheme, then fill in the data for scheduling on it, instead of the visible 'model' object.
Some other notes on cabinets:
Don't try to integrate the countertops and cabinet toes with the cabinet boxes.  They don't do that in the field, and I don't try to do it on my model, either.  My cabinet boxes are discreet elements that I can alter, move, resize, etc., that are placed between a slab element for the toe, and another slab element for the countertop.  It gives you MUCH more control over it's configuration and display in both 2D and 3D modes.
Second, be creative with the cabinets.  There's nothing stopping you from stacking three kitchen counter drawer elements one on top of another.  If you make their edges invisible, you can use a simple, doorless cabinet element to create the end stiles.  A perfect example is a refrigerator which I don't have a true model of in my library... I'll place two doorless cabinet elements on either side of 2-door cabinet with the drawer acting as the top cover panel of the fridge.  I'll then stack a 2-door overhead cabinet on top of the 'fridge' to create the cabinet above (if that's what the design requires).  The two doorless cabinet elements on either side of the 'fridge' cabinet serve as the edge stiles for the refrigerator space, as well as the end stiles of the cabinet above the fridge.  In an elevation, it looks perfect.
On my custom cabinet objects, you can control the face frame conditions around all the edges, which is super-handy.  The only one that's not optimized is the multi-drawer cabinet, which I never took the time to try and figure out how to do the lower rails between the drawers.  Someday I'll figure it out and fix it.  If I need that functionality, I'll often just stack single drawer cabinets to get what I desire.
As far as wine bottles, There's a nifty wine bottle object in my library that does all the standard volume wine bottles, allows you to control their resolution, and also their inclination from standing vertical, to laying on their side and any angle you desire in between.  I've also got a parametric wine racking object based on the 'official' stick-framed wine cellar racks that the real wine snobs prefer.  I'll frequently place the racking object inside of an ordinary cabinet with a glass panel door, load it with bottles and there you go... I wine cooler!
My cabinet objects have a ton of user-definable settings, which I've been meaning to write a 'crib sheet' for, but just haven't had time.  That said, if you're using my cabinet objects, feel free to give me a phone call and I'll give you the quick seminar on using them... Once you learn how they work, you'll be able to do almost anything with them.
The main point is:  Don't get tunnel vision with GDL objects.  Most of the components of a building are simple shapes with a few added do-dads like paneled doors, knobs or some stuff inside them.  Mix and match whatever you need to make 'the shape', then use a separate, dedicated object to store it's data for scheduling or listing.
I still use AC9.... One reason I can is that I took the time to learn how to write a little GDL to make things that do what I need.  Check out my moulding objects... They're much more practical for real-world objects than the complex profile tools because you can control their end miters in both axes, assign materials to them individually, and control their appearance in 2D, 3D and Section completely independently.  In other words, I don't miss the complex profile tool one bit... I've had one already since the early days of AC9.  Yes... You can indeed apply user-defined profiles to them... There's notes on that within their code when you open them up in the GDL editor, you'll see those notes in the 'Comment' script.  Like anything, there's some learning curve, but it's short. 🙂
My opinion is that learning at least rudimentary GDL coding is absolutely crucial to getting the most out of AC, just like learning AutoLISP was crucial to optimizing AutoCAD in the old days.  Always, ALWAYS look 'under the hood' of your CAD / BIM software, or you'll probably be missing a huge proportion of it's true functionality.  It'll require some weekends and off-the-clock time... If you're not into that, then you may be in the wrong profession (and I mean that in the kindest terms; I'm not trying to be snarky).  I was a good manual draftsman in the old days, and I look at digital drafting the same way... I'm always trying to expand my skills.  One of my challenges over the years has been creating digital drawings that are as 'pretty' and as well crafted as our old manual drawings with good lineweights, organized data presentation and logical formatting.  As my mentor once told me years ago, "Good drawings get respect."  That's central to having your great ideas faithfully constructed in the field.
Like I said.. Feel free to call me any time about using any of my GDL objects.  Never mind the hour of the day... Leave a message and I'll call you back.  Not a problem.  If we talk face-to-face, It's easier to see what you're after rather than exchanging a dozen e-mails or forum posts (at least for me).
Hope that helps.
