JMM4JMC wrote:
Yes I've seen the crown that is in the library and it does work...
Hi Jim,
I'm guessing that you've made your crown with the Profiler add-on? If so, just go to the object settings and you have two parameters to adjust the ends: "Cutting angle 1" and 2.
If you find yourself doing lots of custom extrusions, you might like Cigraph's ArchiForma 2.0 which has dynamic hotspots for editing the ends (as well as every point in the profile and much more).
HTH,
One of the forum moderators
AC 28 USA and earlier • macOS Sonoma 14.7.1, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
