Jan Mi
custom door markers
I need to change the door and window marker's, there is an option under settings that says load other door marker, what format should it be for it to work? I need ovals for doors and hexagons for windows.
macOS 26 (Latest Build) - Archicad 29 (Latest Build)
1 Reply 1
David Maudlin
mi_jan:
They are library parts of the Window-Door-Skylight Marker Subtype, so if they are in the loaded libraries would show up as options in the pop-up list. You could also Label the Doors and Windows instead using a Dimension Marker.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
