2009-10-23
05:24 PM
2023-05-24
10:56 AM
Rubia Torres
2009-10-26 06:47 PM
2009-10-26 06:58 PM
2009-10-26 07:38 PM
2009-10-26 08:15 PM
2009-10-27 02:16 PM
2009-11-18 06:31 PM
2009-11-18 09:09 PM
2009-11-18 09:29 PM
Erika wrote:I'm not getting any choices of (sub)type. The list only contains "Archicad Object File".... I tried to save it from the 3D view which give a "door" option but also doesn't seem to work...
After selecting the custom door pieces you created,
If you are in the plan view,
File>Libaries and Objects>Save Selections As>New Library Part.
Subtype Hierarchy>Model Element>Custom Compenent Template>Custom Door Leaf
Do NOTuse Custom Component Collections>Door Panel Collections
2009-11-18 09:36 PM
The type of Custom Components you can save will depend on the loaded libraries.So you need to load that library for the options to appear.
For example, under Windows, the C:\Program Files\Graphisoft\ArchiCAD 13 INT\ArchiCAD Library 13\Custom Object Macros 13 is the place that contains the subtypes defining the types of Custom Components that can be saved. This has to be loaded for them to appear as options - of course they do if you just simply load the ArchiCAD 13 Library.
