details with custom window and door frames
Hey guys
I was wondering what techniques you use to add a detailed window/door frame from a manufacturer on your details (scale 1:5)?
I am asking this cause right now I am importing them from autocad and making them into 2d objects with hotspots, but I already see two problems:
-first the fact that is really easy to resize without noticing making all the detail inaccurate
-second, if i need to add more hotspots,add or remove elements or edit it is just really time consuming
I think making them into a simple group isn't a good solution either so right now i am a bit clueless.
I would really appreciate your thoughts on this one.
Best regards
Luis
3 Replies 3
Erwin Edel
You can lock the A and B parameters by hiding them. Open the object, go to the parameters and under Display cross them out. This should stop the object resizing.
I make 2d objects with hotspots by just pasting the linework and fills into the 2d symbol window. Editing them is just as fast as editing a simple group.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Hi Erwin
thanks for your reply
- I tried that already but you can still change its size by dragging one of the corners. is there any to lock it?
for the 2d object making I will use that option for sure I didn't thought of that solution for the 2d object mak
Erwin Edel
Try adding this bit of 2d script
FRAGMENT2 1,0
www.leloup.nl
