different size sashes for W Sliding3 22 window
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2019-03-04
06:38 AM
2023-05-24
12:26 PM
Rubia Torres
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-03-05 03:53 AM
Then just adjust your widths to desired?
Ling.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-03-05 04:53 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-03-05 05:03 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-03-05 06:14 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-03-05 07:08 AM
Ling.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-03-05 07:41 AM
This is what we have in the AUS library.
We don't have a 'Wood Windows' section like you do.
I didn't realise they were quite so different.
I just had a quick look at the 21 USA library I have installed and I don't see this option there as you say.
Nor can I see a way of doing what you want.
Maybe someone else that uses the USA library will have a suggestion.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-03-05 07:56 AM
Ling.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-03-05 08:06 AM
Lingwisyer wrote:I was thinking this as well, but I see only a 3 sash window for version 19.
Can you DL the window from BIMComponents? Or might the GS objects on there only be top level and not contain the required macros?
It would contain all of the macros and I assume it is the INT library version.
I didn't actually download it but if it is the INT version, I am not sure if it will play nice with the USA library.
Maybe all the macros and objects are completely separate so there may be no issues.
only one way to find out.
Also it is version 19 so not sure how that will go either.
That should still be OK I think.
I would have thought BIM Components would be up to date though.
Especially when it comes to standard Graphisoft library parts.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-03-05 02:13 PM
It does beg the question though. Why was this removed from the newer library and replaced with a window that nobody could ever buy? This is far from the first time I have had to download older versions because the current library doesn't have what I need.
