double door opening setting
I am looking to display in plan a double door which has one panel open and the second panel closed. Where is the setting where I can show this?
Thank you in advance.
The problem is that right now ArchiCAD double doors are written so one parameter controls the opening angle of both wings of the Door.
You would have to modify the (which is possible) GDL Script of these Door to achieve that.
