__archiben
double swinging, double leaf, asymetric 'metal' door?
hi all
does anybody know of a freeware double swinging, doubled leaf door where i can set the sizes of each leaf independently to each other? i.e i can have one smaller door leaf than the other.
i'd also like to be able to 'oversize' it in a similar manner to the standard library ones.
thanks in advance . . .
~/archiben
b e n _ f r o s t
4 Replies 4
Jacek
Can you use a regular double door and just call out the leaf size as 'irregular' -for example a double door, 6 feet wide with a 75% door width ( as an example).
You will find that under Parameters, Door Panel, 50% -default.
The swing in plan you would need to show w/2D line.
Is that what you need?
Jacek
jacek lisiewicz
arkhos-tekton, architects
carmichael, ca
Mac OS X 10.15.5
IMac Retina 5K, Intel Core I7
32 GIG Memory, AMD Radeon R9
ArchiCAD 24
Jacek
Ben,
correction, if you open the 8.1 library, Doors, Wood Internal, D2 Double Acting, and again under the Parameters, Right Panel/Total Panel change the default 50% to whatever size you wish.
No 2D to mess with...
Jacek
jacek lisiewicz
carmichael, ca
Mac OS X 10.15.5
ArchiCAD 24
__archiben
doh!
i only checked the metal doors for this function! i had assumed that the 'D2 Metal' would have all the parameters available in other doors. i ought to have known better i guess!
thanks!
~/archiben
b e n _ f r o s t
Jacek
Happens to the best of us
...and this forum helps to remind one of some of the most obvious things one has forgotten
Jacek
jacek lisiewicz
carmichael, ca
Mac OS X 10.15.5
ArchiCAD 24
