ā2009-04-14 04:30 AM
ā2009-04-14 03:56 PM
ā2009-04-14 04:33 PM
ā2009-04-14 05:36 PM
ā2009-04-15 02:14 PM
sharon wrote:This can also depend on the selected Work Environment.
...I think the instructions are for an older version of archicad. I'm using 12...
sharon wrote:Your experience is typical for parts that are created in another application, then imported into ArchiCAD, rather than written for ArchiCAD using GDL. There is not much to be done about the triangulation (but this should not affect renderings). Unless you know some GDL, you will not be able to make the materials parametric. You might have some control over the scale by changing the A, B and Height parameters of the parts. If you search this forum, you will find others with similar experiences.
Trouble is, some looked very strange (triangulated?) others came through with no parameter for materials, all came in with unusual scale.
Is there more to this than what I'm doing?
