gap between doors in window builder AC12
need some help with this
ive been through every advanced menu for the cadimage door and window builer
i have french doors with sidelights either side and there is a 30mm gap between the doors i want to close it up to nothing ive tried everything
and its just pisin me off now so any help appreciated.
1 REPLY 1
Stephen Dolbee
I have used D&W builder for some time and this has been an issue when using sidelights. Select the door and click on FRAME, then check Mullions and Transoms. Set the appropriate dimensions and that should fix it.
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
