2008-10-26 07:42 PM - last edited on 2023-05-24 10:58 AM by Rubia Torres
2008-10-27 03:08 AM
2008-10-27 04:59 AM
2008-10-27 05:31 AM
2008-11-16 09:02 AM
2013-11-08 05:08 PM
2013-11-09 03:41 PM
Sightline wrote:There is awesome flexibility in good scripted objects, so a 2D workaround is never a good solution - it WILL waste your time down the track when you need to work changes into the model.
Another workaround can be use any other king of door, but closed (d1 commercial for instance). Then, tweak the 2D.
Since the garage doors are limited and lack flexibility in their 3D parameters, it is always easier to complete work in 2D rather than 3D.
Working with BIM, we depend too much on non flexible objects in general. This is a major issue Graphisoft should take care of. It is a waste of time for users trying to find workarounds to libraries that have changed so little on the latest versions of ArchiCAD.
2022-02-22 05:48 PM
Digging up another decade old topic.....
I managed to edit the door as described here, but I would like to change the size of the mullions.
The mullions are clearly visible in the Twinmotion render, and display too slender.
I've been "trial and erroring" the door's settings with no success unfortunately.
I'm using D1 Garage 02 24, Style 5
