grape vine
Does anyone have model of grape vine, or sth like that.I need it quick...Thanks!
7 REPLIES 7
Hello
The better i find is that Fruit basket
Thank you but I was looking for grape vine - a plant (tree), not just fruit....Like in the picture...
Sorry
I don't have then.
Check out Ivy Generator.
http://graphics.uni-konstanz.de/~luft/ivy_generator/
It will "grow" a vining plant. It exports as .obj so you need to convert that to .3ds to get it into ArchiCAD.
This looks cool...but I can't import any object,I thought that I will get them with ivy application but obviously I didn't...
Hi Davor,
As Michael suggested, you'll want to look for models in 3DS format. In order to import 3DS you need to install a free add-on to ArchiCAD that can be downloaded from a web page reached via Help > Goodies
The download includes a help file, but you can also search for '3ds import' in these forums using this search page:
http://archicadstuff.blogspot.com/
You'll find lots of posts to help.
The reason for using that Google search instead of the forum's own search is that the forum software will not search for any term that is 3 characters or less ... and so cannot find "3ds".
You can also import dwg/dxf files as 3d objects by opening them as library parts ... but they will not have any texture maps. The nice thing about 3ds is that any texture maps come along into the created GDL object.
Thanks Karl, this was helpful!
