‎2010-07-02 12:54 AM
‎2010-07-02 11:44 PM
‎2010-07-05 05:08 PM
IF showLoad THEN
rrr=REQUEST ("Area_dimension","",area_form)
room_area = STR (area_form, ROOM_AREA)
net_area_val = ""
n = SPLIT(ROOM_AREA, "%n%s%n", net_area_val2, comma, net_area_val1) ! n = SPLIT(ROOM_AREA,"%n",net_area_val)
net_area_val = net_area_val2 + net_area_val1
occLoad = STR (CEIL(net_area_val/SqFtPerson),1,0)
TEXT2 0,-vOffset, "Occupant Load: " + occLoad
HOTSPOT2 0,-(vOffset)-(strHt2/2)
vOffset=vOffset+strHt2
ENDIF
Where "%n%s%n" is picking up the comma between the thousands and hundreds. This is rough, there may be further refinements depending on your desired result.‎2010-07-06 05:01 PM
