help with zone object
jkershaw
Ok, please forgive my newbie-ness.
I'm attempting to modify an existing zone stamp so that it can actively calculate an occupant load based on the room area and the occupant load factor. It works great until the room gets to be over 1000 SF. Please see image below.
here's the code:
! ====== Place Occupant Text ===================
IF showLoad THEN
rrr=REQUEST ("Area_dimension","",area_form)
room_area = STR (area_form, ROOM_AREA)
net_area_val = ""
n = SPLIT(ROOM_AREA,"%n",net_area_val)
occLoad = STR (CEIL(net_area_val/SqFtPerson),1,0)
TEXT2 0,-vOffset, "Occupant Load: " + occLoad
HOTSPOT2 0,-(vOffset)-(strHt2/2)
vOffset=vOffset+strHt2
ENDIF
I suspect it's something in the SPLIT command, but quite frankly, I'm lost. Any help would be greatly appreciated!
undefined
AC26 APPLE SILICON USA FULL 4032
Mac Studio 2022, Apple M1 Max, 64GB RAM
13.2 macOS Ventura
learning AC since version 4.5
3 REPLIES 3
Maybe it has something to do with the comma at the thousand place. It cannot deal with it because a comma is not a number so it takes the '1' at the beginning of the string.
You can check this: maybe beyond 2000, the result will be 2.
You should use string operations to strip the comma out of the string and then do the calculation.
David Maudlin
jkershaw:
Laszlo is on the right track. The square footage is being returned as a text string, not a number, so the comma will split the string when present when the square footage equals or exceeds 1,000. So you can try:
IF showLoad THEN
net_area_val = ""
n = SPLIT(ROOM_AREA, "%n%s%n", net_area_val2, comma, net_area_val1) ! n = SPLIT(ROOM_AREA,"%n",net_area_val)
net_area_val = net_area_val2 + net_area_val1
ENDIF
Where "%n%s%n" is picking up the comma between the thousands and hundreds. This is rough, there may be further refinements depending on your desired result.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
jkershaw
Laszlo and David -
Thank you SO much for your replies! That is extremely helpful in understanding how to properly parse the string into the component parts. I will give it a shot!
13.2 macOS Ventura
