how make lib parts live with dim in s/e
Erika Epstein
In the section/elevation windows, non-graphisoft parts won't dimension live.
I was wondering if any knows why and what could be added to a script to make it live.
By live I mean when I snap a dimension to a node on an object, if the object is moved, the dimension will follow.
thanks
Erika
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
6 REPLIES 6
__archiben
erika
i think it's less to do with who's made the object and more as to whether or not it includes scripted HOTSPOT nodes rather than just leaving archiCAD to generate nodes at polygonal corners . . . i may be wrong . . .
~/archiben
b e n _ f r o s t
Aussie John
Editable hotspots ( green diamond type) are always associative for dimensions.
Actually they dont need to be editable but have the ID number associated with editable hotspots.
Cheers John
[/size]
Erika Epstein
Ben and JOhn,
You are correct, editable hotspots always give live dimensions in both plan and section/elevation.
I am still puzzled by the behavior of doors or windows being different as to live dimensioning in plan from s/e. In plan dimensions to the edges of the door/win are live dimensions. These same corners in 3D are not. The plan nodes are not the tell-tale diamond of the editable hotspots.
Why then doesn't the same hold true in s/e when dimensioned are attached to the corners of the openings? Are the plan nodes a kind of editable hotspot that doesn't sport the tell-tale diamond appearance?
The doors and windows I tested this on were both graphisoft and 3rd-party ones.
Wouldn't it be good if when you change the height of a door or window that its dimension adjust with the it?
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Aussie John
Erika
2D associative hotspots were a feature of doors and windows long before 3D editable hotspots where just a twinkle in the eye of the developer, so I am guessing door, windows and other 2d elements use a different approach to the hotspot system.
Cheers John
[/size]
Erika Epstein
thanks again John
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
The answer is very easy
Imagine simple GDL object - box AxBxZZYZX
Note You should enter new parameter (in addition to basic A & B) -ZZYZX (exactly the name zzyzx !!!)
The 3D script will look like this
BLOCK a,b,zzyzx
HOTSPOT 0,0,0
HOTSPOT a,0,0
HOTSPOT a,b,0
HOTSPOT 0,b,0
HOTSPOT 0,0,zzyzx
HOTSPOT a,0,zzyzx
HOTSPOT a,b,zzyzx
HOTSPOT 0,b,zzyzx
Hotspots should be placed exactly in object corner positions (a,b,xxyzx)
All dimensions will be editable from 3D view
Note that even on 2D view hotspots shoud be placed into these points - otherwise object willn't be ediotable by drag&drop
Why 'non'-graphisoft developers doesn't sometimes follow this rule ? - perhaps they simply doný know it or doesn't care about 3D window editing.
For example I done more then 300 different objects - from simple ones t overy-very complicated ones (150-200 kB program text) - but I also offen don't put featured 3D hotspots
Hope this answer will find You well
