how to hide my parameters programmatically.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2008-03-10 08:04 AM
‎2008-03-10
08:04 AM
if marker="Section"
hide parameter
else
visible parameter
endif
any suggestion?
tnx
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-03-10 09:16 AM
‎2008-03-10
09:16 AM
mackyboy wrote:close . . .
any suggestion?
!! if these are the parameters you want to hide... myParameter1 = 1 myParameter2 = 2 myParameter3 = 3 !! ...this is the code if marker = "Section" then hideparameter myParameter1, myParameter2, myParameter3 endif !! you don't need a "showparameter" control because !! it will always be visible unless you hide it. !! i.e. if 'marker' is NOT "Section" it will be visible. !! you may also want to lock them at the same time... if marker = "Section" then hideparameter myParameter1, myParameter2, myParameter3 lock myParameter1, myParameter2, myParameter3 endif !! ...or you can simply lock them without the hiding so that !! the user knows that they exist. may be an option?be sure to put this kind of code in the
~/archiben
b e n f r o s t
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-03-10 08:44 PM
‎2008-03-10
08:44 PM
The parameter names should be in quotes if you hide or lock;
if mySetting= "Hide them" then
hideparameter "myParam1", "myParam2"
endif
if mySetting= "Lock them" then
lock "myParam1", "myParam2"
endif
if mySetting= "Change them" then
parameters myParam1="No quotes here", myParam2="Or here"
endif
endif
endif
endif
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-03-11 04:06 AM
‎2008-03-11
04:06 AM
many thanks
