image as GDL object
hello.. I need some help... I need to put an imagine in 3D. I know that I should create on object. and I done this, but I don't know how to do tu be seen in 3D , am my picture is horizontaly, and I would like to be verticaly..
PS sorry for my bad english, hope someoane will understand
Erika Epstein
You could create a new material and apply the image. In the material attributes window take a look at one of the standard materials such as Common Bond that have a photo image attached.
In the 3D window you can reorient the image.
It would be best to rotate the image in a photo editor like photoshop first, but not necessary.
HTH
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
There is a 'Picture' object in the standard INT ArchiCAD library under 'Furnishing'>'Decoration' that can display an individual picture vertically.
Dwight has also uploaded his 'Parapicture' object to the depository, which is similar but has more features. It's at the bottom of this list -
http://archicad-talk.graphisoft.com/object_depository.php?browse=Depository/01+General
These may be more convenient to adjust, depending on what you need it for.
