library AC11 PT
Hello, i am using AC 14 in English, but with a old project that has been created in Ac 11 with the Portuguese library. now many of the objects are not recognized.
I have already installed the migration libraries, but didn´t work, maybe because of the language.
I want to know if anybody has a solution and if you can give me a way to find the Portuguese library of the AC 11
Thanks
2 Replies 2
There is probably no easy substitute for getting the original library.
You might be able to use Find & Select by name and try to replace them with similar parts from the libraries you have. I realize that this might be very difficult and frustrating depending on the circumstances and I'm also not sure whether it would work with missing parts.
I would suggest contacting you local reseller Infor and asking for it.
