mesh dependant height label
Hi everyone.
Is there any way to label mesh vertices height on plan?
I know there is a 'coordinate dimension' object in a standard library but it's not connected to a vertex and needed to set up manually.
David Maudlin
archimax:
Use the Level Dimension Tool with Gravity set to Mesh. The Level Dimensions will be associated to the Mesh, the displayed height value will change as the Mesh points are altered.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David wrote:
archimax:
Thanks for your tip David. That's exactly what I was looking for!
