2024-08-23 04:17 PM
Hi, I recently updated to Archicad 26, and for some reason when I open up an existing Archicad 26 project, I am missing the "Section Part marker_NCS 26.gsm" and the "NCS Drawing Title 2 26.gsm". These two library parts are commonly used in projects in our office.
Could someone please tell me how to resolve this issue? I don't know how to relink them, or where to look for them.
Thank you!
Operating system used: Mac Intel-based Sonoma
Solved! Go to Solution.
2024-08-24 01:55 PM
Loutro:
They are located in the Object Library 26.lcf, which is in the Archicad Library 26 folder (/Applications/GRAPHISOFT/Archicad 26/Archicad Library 26). Make sure that the Archicad Library 26 is one of your loaded libraries.
2024-08-24 01:55 PM
Loutro:
2024-09-03 04:16 PM
Thanks David. It turns out that I had installed the incorrect language version of Archicad 26. I had "English (International)" instead of "English (U.S.A.)." I uninstalled and reinstalled the correct one and this solved the problem, but thanks for letting me know where the library parts are located in any case.
Loutro
2024-09-04 04:04 AM
I think the NCS objects are only in the USA library, which is why your re-install worked.
2024-09-04 05:02 AM
Surprised you were not missing all your doors and windows as the US library uses different ones there too... though I guess you are using a 3rd party library for those.
a week ago
I am having exactly same issue and I am in archicad 29....
a week ago - last edited a week ago
You will run into this issue when migrating from any pre-Libpack version. You could possibly find and load the old NCS library?
a week ago
If you are opening files is 29 that use objects from 27 or before, you must also load those old libraries.
Old objects will not migrate to the 28/29 libraries.
a week ago
Actually the file should be brand New in 29, and it’s empty (I removed the project). Which is why it’s strange it’s says it’s missing, and also missing when the file is empty (nothing is built?)
"Removing a project" does not change anything... It will still be a pre-libpack file. If you have any attributes or favourites, they will all show as missing.
