Loutro
missing library objects
Hi, I recently updated to Archicad 26, and for some reason when I open up an existing Archicad 26 project, I am missing the "Section Part marker_NCS 26.gsm" and the "NCS Drawing Title 2 26.gsm".  These two library parts are commonly used in projects in our office.
Could someone please tell me how to resolve this issue?  I don't know how to relink them, or where to look for them.
Thank you!
Operating system used: Mac Intel-based Sonoma
Mac OS 14.6.1
Archicad 24 & 26
1 Solution
David Maudlin
Loutro:
They are located in the Object Library 26.lcf, which is in the Archicad Library 26 folder (/Applications/GRAPHISOFT/Archicad 26/Archicad Library 26). Make sure that the Archicad Library 26 is one of your loaded libraries.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Go to post
4 Replies 4
David Maudlin
Loutro:
Loutro
Thanks David.  It turns out that I had installed the incorrect language version of Archicad 26.  I had "English (International)" instead of "English (U.S.A.)."  I uninstalled and reinstalled the correct one and this solved the problem, but thanks for letting me know where the library parts are located in any case.
Loutro
Mac OS 14.6.1
Archicad 24 & 26
I think the NCS objects are only in the USA library, which is why your re-install worked.
Lingwisyer
Guru
Surprised you were not missing all your doors and windows as the US library uses different ones there too... though I guess you are using a 3rd party library for those.
