‎2024-08-23 04:17 PM
Hi, I recently updated to Archicad 26, and for some reason when I open up an existing Archicad 26 project, I am missing the "Section Part marker_NCS 26.gsm" and the "NCS Drawing Title 2 26.gsm". These two library parts are commonly used in projects in our office.
Could someone please tell me how to resolve this issue? I don't know how to relink them, or where to look for them.
Thank you!
Operating system used: Mac Intel-based Sonoma
Solved! Go to Solution.
‎2024-08-24 01:55 PM
Loutro:
They are located in the Object Library 26.lcf, which is in the Archicad Library 26 folder (/Applications/GRAPHISOFT/Archicad 26/Archicad Library 26). Make sure that the Archicad Library 26 is one of your loaded libraries.
Loutro:
‎2024-09-03 04:16 PM
Thanks David. It turns out that I had installed the incorrect language version of Archicad 26. I had "English (International)" instead of "English (U.S.A.)." I uninstalled and reinstalled the correct one and this solved the problem, but thanks for letting me know where the library parts are located in any case.
Loutro
‎2024-09-04 04:04 AM
I think the NCS objects are only in the USA library, which is why your re-install worked.
‎2024-09-04 05:02 AM
Surprised you were not missing all your doors and windows as the US library uses different ones there too... though I guess you are using a 3rd party library for those.
