open web trusses
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2021-04-22
12:41 AM
2023-05-23
04:04 PM
Rubia Torres
2021-04-22
12:41 AM
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
Visual Frontiers
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-04-22 03:24 AM
2021-04-22
03:24 AM
Not sure if this is exactly what you are after, but have you tried the 'Metal Web Joist' object?
Otherwise I am sure you are aware of the 'Trussmaker add-on (not parametric).
Barry
Barry
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-04-23 02:43 AM
2021-04-23
02:43 AM
Thanks Barry...
I did see that one... Can't quite get what I want out of it...
I did however, dust off the old TRUSSMAKER... I like it... but wish that it could support different shapes and materials for the CHORDS and the WEBBING... I just did them all as SQUARE TUBE and made the webbing THINNER... Looks great in SECTION (don't miss that the webs aren't circular)... and it passes the squint test in 3d...
Duane
Visual Frontiers
Visual Frontiers
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-04-23 06:23 AM
2021-04-23
06:23 AM
I make my trusses using complex profiles these days and add them into the model as short beams. If you need different section profiles you could merge two or more beams. Or you could form them properly with beams and save as a module (HLM). If only we had an in place editor...
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-04-23 11:50 AM
2021-04-23
11:50 AM
This does sound like something you could achieve with Param-O.
I've yet to sink my teeth in to that, but I've seen some clips from our reseller on LinkedIn that look quite promising!
Another option that sometimes works is Curtain Wall tool.
I had to make a space frame for an existing (renovation) building a while back and I was able to combine the simple 3D form objects into a module and copy these around.
And finally 'just' regular GDL if you are any good with it.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
www.leloup.nl
Windows 10 Pro
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-04-24 01:13 AM
2021-04-24
01:13 AM
DGSketcher wrote:Same here... but my PROFILE EDITOR gets really LONG... wish we could FOLDERIZE / ORGANIZE that list!...
Duane
Visual Frontiers
Visual Frontiers
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-04-26 02:53 AM
2021-04-26
02:53 AM
One of the largest drawbacks in using TRUSSMAKER is that because everything is defined by CENTERLINE, the resulting object has no NODES at corners.. This makes placement more difficult. Pretty much have to use sections to get proper placement..
FWIW...
FWIW...
Duane
Visual Frontiers
Visual Frontiers
