ivarheggheim
Opening files automically opens in story level 0/1 (lowest story level)
opening files in Archicad 28 has changed since previous version. An annoying new feature is that all excisting files you open, always opens up in story level 0/1. It doesnt remember anymore, which story you last worked on. This is extremely annoying when you have a lot of hotlinks, and you always have to move up/down to the story you worked last time you opened the file.
Can I turn off this function, and why has it been implemented?
I tried to reproduce this, but I could not; for me, Archicad 28 behaves exactly as expected - it always opens the TAB I was on when I last saved, and if it was the Stories TAB, it will always take me back to the Story I was on last time I saved.
I am using Ac28 INT 28.1.1.
Which localization are you using?
Also, did you install the latest Update/Hotfix? (just to make sure)
ivarheggheim
Hi Laszlo,
I am using the Norwegian localization, and we are using the latest update/hotfix.
