Opening files automically opens in story level 0/1 (lowest story level)
ivarheggheim
opening files in Archicad 28 has changed since previous version. An annoying new feature is that all excisting files you open, always opens up in story level 0/1. It doesnt remember anymore, which story you last worked on. This is extremely annoying when you have a lot of hotlinks, and you always have to move up/down to the story you worked last time you opened the file.
Can I turn off this function, and why has it been implemented?
I tried to reproduce this, but I could not; for me, Archicad 28 behaves exactly as expected - it always opens the TAB I was on when I last saved, and if it was the Stories TAB, it will always take me back to the Story I was on last time I saved.
I am using Ac28 INT 28.1.1.
Which localization are you using?
Also, did you install the latest Update/Hotfix? (just to make sure)
Hi Laszlo,
I am using the Norwegian localization, and we are using the latest update/hotfix.
