parametric chair difficulties
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2010-01-04 02:43 PM
I need some help here.All I did was to follow,step-by-step,the exact instructions of the guide.
here is the master script
!Pop down Menu
bv0="No leg braces"
bv1="O brace"
bv2="H brace"
VALUES "bracetype", bv0, bv1, bv2
IF bracetype=bv0 THEN
brace=0
ELSE
brace=1
ENDIF
MATERIAL lmat
IF bakon=0 THEN arms=0
IF bakon=0 THEN strot=0
!Menu for Chair
cv0='Customised chair'
cv1='Foot stool'
cv2='Nursery chair'
cv3='Piano stool'
cv4='Dining chair'
cv5='Dining armchair'
cv6='Kitchen stool'
cv7='Bar stool'
VALUES 'chairtype', cv0,cv1,cv2,cv3,cv4,cv5,cv6,cv7
IF chairtype<>cv0 THEN
!Grey out custom parameters
LOCK 'stlgth','stwidth','stheight'
LOCK 'lsec','backsec'
LOCK 'bakon','bracetype','backheight','arms'
ENDIF
IF chairtype =cv1 THEN !Footstool
stlgth=0.35: stwidth=0.30: stheight=0.28:
lsec=0.04: backsec=0.04: arms=0
bakon=0: bracetype=bv0
ENDIF
IF chairtype =cv2 THEN !Nursery chair
stlgth=0.30: stwidth=0.35: stheight=0.32:
lsec=0.04: frsec=0.04: arms=0
bakon=1: bracetype=bv0: bheight=0.5
ENDIF
IF chairtype =cv3 THEN !Piano stool
stlgth=0.45: stwidth=0.40: stheight=0.45:
lsec=0.05: backsec=0.1: arms=0
ENDIF
IF chairtype =cv4 THEN !Dining chair
lsec=0.05: backsec=0.05: arms=0
bakon=1: bracetype=bv1: backheight=0.55
ENDIF
IF chairtype =cv5 THEN !Dining armchair
stlgth=0.50: stwidth=0.45: stheight=0.45:
lsec=0.05: backsec=0.05: arms=1
bakon=1: bracetype=bv1: backheight=0.65
ENDIF
IF chairtype =cv6 THEN !Kitchen stool
stlgth=0.35: stwidth=0.40: stheight=0.60:
bakon=0: bracetype=bv2
ENDIF
IF chairtyp =cv7 THEN !Bar stool
stlgth=0.35: stwidth=0.40: stheight=0.65:
bakon=1: bracetype=bv2: backheight=0.3
ENDIF
and here is the 3D script
PEN 1
RESOL 12
!All the legs
MATERIAL lmat
!lsec/3 is the down leg diameter
CONE lgheight, lsec/3, lsec/2, 90,90
ADDx stlgth
ADDy stwidth
ADDx -stlgth
DEL 3
!seat and upholstery
ADDz stheight
ROTx -3
BLOCK stlgth,stwidth,stthick
MATERIAL stmat
ADD 0.025,0.025,0.045
BLOCK stmatlth,stmatwdth,stmatthick
DEL 3
!Back Legs, panel and upholstery
IF bakon THEN
MATERIAL framat
ADD 0,stwidth,stheight + stthick + stmatthick
CONE backheight - 0.1,0.03,0.02, 90,90 !leg
ADDx stlgth
DEL 2
ADD 0,stwidth-0.02,backheight !back panel
ROTx -2
BLOCK 0.45,backsec,0.35
MATERIAL backmat
ADD 0.05,-0.01,0.02 !back material
BLOCK 0.35,0.01,0.30
DEL 3
ENDIF
MATERIAL lmat
!Braces front to rear
IF bracetype=bv2 THEN !H Brace
ADDz lgheight/3
ADDx lsec/8
ROTx -90
CONE 0.5/2,lsec/4,lsec/3,90,90
ADDz 0.5/2
CONE 0.5/2,lsec/3,lsec/4,90,90
DEL 4
ADD stlgth,lsec/8,lgheight/3
ROTx -90
CONE lgheight/2,lsec/4,lsec/3,90,90
ADDz lgheight/2
CONE lgheight/2,lsec/3,lsec/4,90,90
DEL 3
ADD 0,0.25,lgheight/3
ROTz -90
ROTx -90
CONE stlgth/2,lsec/4,lsec/3,90,90
ADDz stlgth/2
CONE stlgth/2,lsec/3,lsec/4,90,90
DEL 4
ENDIF !brace=bv2
IF bracetype=bv1 THEN !O Brace
ADD 0,0,stheight/3
ROTz -90
ROTx -90
ADDz stlgth/2
DEL 4
ADD 0,stwidth,stheight/3
ROTz -90
ROTx -90
ADDz stlgth/2
DEL 4
ADDZ stheight/3
ROTX -90
CONE stwidth/2,lsec/4,lsec/3,90,90
ADDz stwidth/2
CONE stwidth/2,lsec/3,lsec/4,90,90
DEL 3
ADDx stlgth
ADDz stheight/3
ROTx -90
ADDz stwidth/2
DEL 4
ENDIF
!arms option
IF arms THEN
ADDz backheight !left
ADDy -backheight/6
ROTx -90
MULy 0.5 !Squash the arm cone to an ellipse
CONE stwidth + (backheight/6),lsec/2,lsec/3,90,90
DEL 4
ADDz stheight + stthick + stmatthick
CONE (backheight/3) - 0.06 , lsec/2 , lsec/3 , 90 , 90
DEL 1
ADDx stlgth
ADDz backheight !right
ADDy -backheight/6
ROTx -90
DEL 5
ADDx stlgth
DEL 2
ENDIF
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-01-04 07:26 PM
I also noticed you have mis-spelled chairtyp =cv7 in the Masterscript. Should be chairtype =cv7.
Hope that sorts it!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-01-04 11:48 PM
if "chairtype"<>cv0...
if "chairtype"=cv1...
..and so on..
now the problem is that the 3d view of my object does not react to any change of the value of "chairtype"...
i am wondering,does some part of the script need to be written inside the 3d script and some other part inside the master script? is that my mistake?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-01-05 01:33 AM
where you have part of the script like this
ENDIF
are all these parameters? if so you will need to change the script to read like this
parameters stlgth=0.35, stwidth=0.30, stheight=0.28,
lsec=0.04, backsec=0.04, arms=0,
bakon=0, bracetype=bv0
ENDIF
This applies to every other parameter you are trying to change its value in the Parameter or Master Script tabs. If it is a variable however, it does not need to use the parameter command.
Hope that helps...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-01-05 08:35 PM
here is an example
IF "chairtype" =cv1 THEN !Footstool
PARAMETERS arms=0, bakon=0, bracetype=bv0
ENDIF
the error message indicates the second line
any ideas?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-01-05 10:48 PM
ENDIF
It may be a personal preference but i would actually write the script like this, much easier to read once you have to find it and read it quickly amoungst hundreds of lines of script.
!Footstool
if "chairtype" =cv1 then
stlgth=0.35
stwidth=0.30
stheight=0.28
lsec=0.04
backsec=0.04
parameters arms=0,
bakon=0,
bracetype=bv0
endif
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-01-06 01:18 PM
3d script
PEN 1
RESOL 12
!All the legs
MATERIAL lmat
ADDx stlgth
ADDy stwidth
ADDx -stlgth
DEL 3
ADDz stheight
ROTx -3
MATERIAL stmat
DEL 3
IF bakon THEN
MATERIAL framat
ADDx stlgth
DEL 2
ROTx -2
BLOCK backlgth,backsec,backlgth-10
MATERIAL backmat
DEL 3
ENDIF
MATERIAL lmat
ADDz lgheight/3
ADDx lsec/8
ROTx -90
ADDz 0.5/2
DEL 4
ROTx -90
ADDz lgheight/2
DEL 3
ROTz -90
ROTx -90
ADDz stlgth/2
DEL 4
ENDIF !brace=bv2
ADD 0,0,stheight/3
ROTz -90
ROTx -90
ADDz stlgth/2
DEL 4
ROTz -90
ROTx -90
ADDz stlgth/2
DEL 4
ADDZ stheight/3
ROTX -90
ADDz stwidth/2
DEL 3
ADDx stlgth
ADDz stheight/3
ROTx -90
ADDz stwidth/2
DEL 4
ENDIF
!arms option
IF arms THEN
ADDy -backheight/6
ROTx -90
DEL 4
DEL 1
ADDx stlgth
ADDy -backheight/6
ROTx -90
DEL 5
ADDx stlgth
DEL 2
ENDIF
master script
!Pop down Menu
bv0="No leg braces"
bv1="O brace"
bv2="H brace"
brace=0
ELSE
brace=1
ENDIF
MATERIAL lmat
brace=0
ELSE
brace=1
ENDIF
MATERIAL lmat
IF bakon=0 THEN arms=0: strot=0
!Menu for Chair
cv0="Customised chair"
cv1="Foot stool"
cv2="Nursery chair"
cv3="Piano stool"
cv4="Dining chair"
cv5="Dining armchair"
cv6="Kitchen stool"
cv7="Bar stool"
VALUES "chairtype" ,cv0,cv1,cv2,cv3,cv4,cv5,cv6,cv7
!Customized chair
IF "chairtype"<>cv0 THEN
LOCK 'stlgth',
'stwidth',
'stheight',
'lsec',
'backsec' ,
'bakon',
'bracetype',
'backheight',
'arms'
ENDIF
!Footstool
stlgth=0.35
stwidth=0.30
stheight=0.28
lsec=0.04
backsec=0.04
ENDIF
!Nursery chair
IF "chairtype" =cv2 THEN
stlgth=0.30
stwidth=0.35
stheight=0.32
lsec=0.04
frsec=0.04
bheight=0.5
PARAMETERS arms=0, bakon=1, bracetype=bv0
ENDIF
!Piano stool
IF "chairtype" =cv3 THEN
stlgth=0.45
stwidth=0.40
stheight=0.45
lsec=0.05
backsec=0.1
ENDIF
!Dining chair
IF "chairtype" =cv4 THEN
stlgth=0.45
stwidth=0.40
stheight=0.45
lsec=0.05
backsec=0.05
backheight=0.55
PARAMETERS bakon=1, bracetype=bv1, arms=0
ENDIF
!Dining armchair
IF "chairtype" =cv5 THEN
stlgth=0.50
stwidth=0.45
stheight=0.45
lsec=0.05
backsec=0.05
backheight=0.65
PARAMETERS bakon=1, bracetype=bv1, arms=1
ENDIF
!Kitchen stool
IF "chairtype" =cv6 THEN
stlgth=0.35
stwidth=0.40
stheight=0.60
lsec=0.05
backsec=0.05
PARAMETERS bakon=0, bracetype=bv2, arms=0
ENDIF
!Bar stool
IF "chairtype" =cv7 THEN !Bar stool
stlgth=0.35
stwidth=0.40
stheight=0.65
lsec=0.05
backsec=0.05
backheight=0.3
PARAMETERS bakon=1, bracetype=bv2, arms=0
ENDIF
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-01-06 01:49 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-01-12 01:11 AM
In terms of changing the "chair type" there were a few places where you had the parameters and variable command mixed up. Any changes you want to make to a parameter listed in the object you need to use the PARAMATER command. Any not listed as parameters you dont need it. I have fixed these and rewritten this part so the values of the chair type work correctly
IF bakon=0 THEN !!!!!!!!!!!!!!!Need to put on separate lines and missing endif
arms=0
strot=0
ENDIF
!!Menu for Chair
!cv0="Customised chair"
!cv1="Foot stool"
!cv2="Nursery chair"
!cv3="Piano stool"
!cv4="Dining chair"
!cv5="Dining armchair"
!cv6="Kitchen stool"
!cv7="Bar stool"
!VALUES "chairtype" ,cv0,cv1,cv2,cv3,cv4,cv5,cv6,cv7
!Rewrite the above to
VALUES "chairtype" "Customised chair",
"Foot stool",
"Nursery chair",
"Piano stool",
"Dining chair",
"Dining armchair",
"Kitchen stool",
"Bar stool"
if chairtype="Customised chair" then chairtypefinal="cv0"
if chairtype="Foot stool" then chairtypefinal="cv1"
if chairtype="Nursery chair" then chairtypefinal="cv2"
if chairtype="Piano stool" then chairtypefinal="cv3"
if chairtype="Dining chair" then chairtypefinal="cv4"
if chairtype="Dining armchair" then chairtypefinal="cv5"
if chairtype="Kitchen stool" then chairtypefinal="cv6"
if chairtype="Bar stool" then chairtypefinal="cv7"
!Customized chair
IF chairtypefinal <> "cv0" THEN !!!!!!!!!!!!remove brackets and changed variable
LOCK 'stlgth',
'stwidth',
'stheight',
'lsec',
'backsec' ,
'bakon',
'bracetype',
'backheight',
'arms'
ENDIF
!Footstool
IF chairtypefinal = "cv1" THEN !!!!!!!!!!!!changed
PARAMETERS stlgth=0.35,
stwidth=0.30,
stheight=0.28,
lsec=0.04,
backsec=0.04,
arms=0,
bakon=0,
bracetype=bv0
ENDIF
!Nursery chair
IF chairtypefinal ="cv2" THEN !!!!!!!!!!!!changed
PARAMETERS stlgth=0.30,
stwidth=0.35,
stheight=0.32,
lsec=0.04,
arms=0,
bakon=1,
bracetype=bv0
bheight=0.5
frsec=0.04
ENDIF
!Piano stool
IF chairtypefinal ="cv3" THEN !!!!!!!!!!!!changed
PARAMETERS stlgth=0.45,
stwidth=0.40,
stheight=0.45,
lsec=0.05 ,
backsec=0.1 ,
arms=0,
bakon=0,
bracetype=bv0
ENDIF
!Dining chair
IF chairtypefinal ="cv4" THEN !!!!!!!!!!!!changed
stwidth=0.40,
stheight=0.45,
lsec=0.05,
backsec=0.05,
backheight=0.55,
bakon=1,
bracetype=bv1,
arms=0
ENDIF
!Dining armchair
IF chairtypefinal ="cv5" THEN !!!!!!!!!!!!changed
PARAMETERS stlgth=0.50,
stwidth=0.45,
stheight=0.45,
lsec=0.05,
backsec=0.05,
backheight=0.65,
bakon=1,
bracetype=bv1,
arms=1
ENDIF
!Kitchen stool
IF chairtypefinal ="cv6" THEN !!!!!!!!!!!!changed
stwidth=0.40,
stheight=0.60,
lsec=0.05,
backsec=0.05,
bakon=0,
bracetype=bv2,
arms=0
ENDIF
!Bar stool
IF chairtypefinal ="cv7" THEN !Bar stool !!!!!!!!!!!!changed
stwidth=0.40,
stheight=0.65,
lsec=0.05,
backsec=0.05,
backheight=0.3,
bakon=1,
bracetype=bv2,
arms=0
ENDIF
Good luck!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-01-12 11:47 AM
