‎2006-06-27 12:20 AM
‎2006-06-29 08:39 AM
Weston wrote:Our main library was based on the standard Archicad library (some years ago).Eric wrote:Well, sort of. I'm not clear on whether you even load the AC library in your typical job...
I keep the standard AC library as-is and modify parameters through favorites mostly. I don't edit the code of the GS parts.
Is that what you were asking?
So do you load the "culled" AC parts as a part of your office library, and then load the full AC library for those times when you need the grand piano part that you never bothered to cull?
I had experimented with that a couple of years ago, and always found that the duplicate library parts/duplicate names would cause confusion.
Wes
‎2006-06-29 03:31 PM
‎2006-06-29 04:33 PM
Eric wrote:I second the opinion that the default library structure is not user friendly. The find feature was a very welcome addition to the library browser. Graphisoft could easily have several versions of the same library available with alternate organizational structures. I now this would be welcome to many new users who stumble their way through finding the correct library part.
I use a completely different folder structure for our libraries (see attached) where the folders are named according to the layer hierarchy. This gives the users a hint as to where the part should go if there is no favorite defined. It also gives a hint as to where the part will be visible in the drawings and helps predict the outcome. Having things organized by CSI division is not really helpful to the people that are doing the drawings - at least not how we do it. CSI divisions are pretty much meaningless to the model as it appears on paper.
‎2006-06-29 04:55 PM
‎2006-06-29 05:27 PM
F. wrote:I will have to play with that more. It does seem like a good approach. Can objects have multiple sub-types so they appear in more than one location?
Have you tried to select your objects from the tree "by subtype"?
I wouldn't like to get deifferent sortet libraries. It would be better to improve the subtyp-priniciple, if necessary.
‎2006-06-29 05:40 PM
Mike wrote:No, Subtypes are unique. An object can be either a door or a window or a stair, but not combinations of the 3.F. wrote:I will have to play with that more. It does seem like a good approach. Can objects have multiple sub-types so they appear in more than one location?
