rotate library parts
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2008-08-12 05:35 PM
when placing an object (library part) is there a method to allow it to rotate freely, according to mouse movement while placing? I have a situation where I need to pace several library parts, and they are all at different angles. It is a real pain to place then have to rotate. From my Autocad days, I recall that one could click the insertion point, then rotate the part to the desired angle. I thought I recalled doing this in Archicad, but I cannot find a method, toggle, check box, anything that will allow it to happen.
Also, I long for dynamic preview of ALL library parts!
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-08-12 05:55 PM
I am brain dead this morning. Still want true dynamic preview though!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-08-12 05:56 PM
Rip wrote:It could stand some improvement but there is a preview pane in the settings dialog.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-08-13 05:12 PM
Rip wrote:
when placing an object (library part) is there a method to allow it to rotate freely, according to mouse movement while placing? ... I thought I recalled doing this in Archicad, but I cannot find a method, toggle, check box, anything that will allow it to happen.
Thanks!
I'm glad you figured it out, but I'm still looking for the answer. And now, based on your second post, I'm feeling a bit of a fool for not being able to find it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-08-13 10:38 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-08-14 12:32 AM
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-08-30 08:27 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-08-30 10:27 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-08-31 12:05 AM
seamor101 wrote:OBJECTiVE provides a tool which makes rotating objects in any axis as easy as the built-in rotation tool. Referring to the attached image:
Now can someone tell me how to achieve similar success rotating objects through the z axis? Does this require writing script and if so is there a simple approach for the uninitiated?
- 1) Select any (GDL) object in the floor plan (or in a section/elevation window) and select "OBJECTiVE/Tools/Rotate"
2) Define a rotation axis and start/end angles, much as you would do for 2D rotation (you can use the Coordinates palette and/or Tracker too)
3) The object is rotated (shown in plan and 3D window), and hotspots are placed on the 3D body for easy snapping. There is no need to mess about resaving objects for this to work.
Central Innovation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-08-31 02:53 AM
comes up again and again and there have been at least
three work arounds offered in this forum. One, edit the
3D script with rotx and roty transformation commands,
but unless the 2D script is also edited, the 2D symbol
will not be correct. Two, obtain the Cigraph plug-in
"ArchiRotate" which, even though Free, involves obtaining
a Cigraph license. Three, purchase "OBJECTiVE" which is
an excellent add-on/plug-in but is not inexpensive.
Realizing there was a call for the ability to rotate objects
and being inspired by Karl Ottenstein's "skewer.gsm",
I wrote a very simple library part that rotates a library part
in three axes. It is not fancy, it has it's problems, but its Free
and I offer it here for what it is worth. See Attached.
Peter Devlin
