Streamline your workflows and master BIM coordination! Program starts April 28.!
saved view name
Hello.
Is it possible in a GDL object to get the name of the saved view in the view map?
I would like to change the appearance of the object in 2D according that name.
sinceV6
Hi.
Not sure, but I don't think so. You would be driving object appearance based on the already saved view. I think it works the other way around: using model view options, giving the object the desired look and then saving the view.
There's a simple tutorial (so you understand the basics) of Library Globals over at onLand.
Unless you are talking about using it in a title object, then that's possible.
Best regards.
Thank you!
Library Globals sounds perfect for that!
