segmented arch in 16' garge door (want a smooth arch)
I know that the magic wand settings...points along arc, somehow control the curve in the garage door settings, but have forgotten exactly what to do. My garage door has three jumps and I want a curve. What do I do to get this in my elevation.
Hi
Are you placing a garage door object into a curved wall?
can you give the object name (for the door) to check what can be the problem?
Cheers
Nando
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
Steve Jepson
Try changing the curve resilution to about 60 or so. I set mine to 99.
By null at 2010-07-29
